Yes, I know. Need to get to the dealer. Just wondering if anyone else was going through the same problem. It will turn on the rear camera when going forward. It will show the screen that you are too close to another object, when in drive stopped at a light. Radio settings come up and can't get rid of it. :eek:
Were you going in Reverse and then put it in drive?
That happened on all my Volvos and still happens on the SPA cars. Distance sensors are too sensitive to everything.
Mine aren't bad at all. I had a Lincoln mkx and the obstacle detectors would go of when if brake hard.
Everything you are describing sounds like normal operation except the radio settings stuff.
