Can anyone offer a solution? Once the belt is worn by my passeneger, while we corner on these lovley country roads my passeneger seatbelt will squeak. Advise on what to lubricate?<p>Alex
Discussion Starter · #2 ·
Re: seatbelt squeaky (lexefx)
So everyone has silent seatbelts? This isn't the only XC I have driven where they squeek. Any ideas?
Start by seeing if you can make it stop. On my car, the little frame around where it enters the trim is loose and rattles, yours might be squeaking.<p>Other than that just poke at it to see if you can stop it, then lube what you poke.
We've got the same problem in my V70R. Drives my wife crazy when she rides with me. I'll check the trim, not sure what will fix it.
