1 - 2 of 2 Posts
so in my quest to restore my car to a respectable condition, my passenger seat has failed...the motor s <I></I> seems <I></I> to work when i pull the red lever behind the seat. BUT the seat will not move in either direction using the side panel controls...thus at this point, the seat is moved forward to a ridiculous point so that passengers struggle to safely sit in the seat. Any suggestions on what could be the problem?
Re: seat problem (tigger4mayor)
Could be a couple of things but I would guess the switch, they go bad quite often.<br>Also check the connections under the seat, they can (and do) pull out
1 - 2 of 2 Posts
