1 - 8 of 8 Posts
I have a quick question. Currently the seat memory seems to be a bit broken. The mirrors do move the the approriate position when you press a memroy button, but the seat does not.
The seat controls do work - that is, the seat moves when you use the buttons to move the seat.
Is there a way to "reset" the seat memory? I tried to search but did not have any luck.
Thanks!
Re: Seat memory reset? (PhilUp)
Nope - it doesn't "take" if that makes sense.
I also think that if I disconnect the main battery this memory is retained, right?
Modified by FastWgn at 2:15 PM 5-27-2009
Re: Seat memory reset? (FastWgn)
Not sure, gonna have to defer to someone more knowledgeable. Sometimes my position buttons lose their memory like you describe but I'm able to re-program them.
Re: Seat memory reset? (xman03)
Quote, originally posted by xman03 »
Try pulling the fuse, I had an odd problem where the seat would not move at all which was cured by pulling the fuse for a minute.
Thank you - I will try that. Anything you need to do to actually reset the memory? I recall that it retain its contents even when you discinnect the battery.
My '01 did this awhile ago.
To fix it I turned the car off;
Got out of the car;
Locked the car with the FOB;
Unlocked the car with the FOB;
Got in the car and started the engine;
Moved seat to my preferred position;
Pressed the MEM button along with the desired number.
I read this on another forum somewhere and it worked for me. The seat has remembered ever since.
Fixed!
Removed the fuse the seat, pressed a button to make sure it was completely drained of power, and reinsert the fuse.
Now the memory works again. Thanks for the advice!
1 - 8 of 8 Posts
