1 - 1 of 1 Posts
SC-901 3 Disc Changer Cartridge Problem - Now fixed
Greetings all! I need some help with my SC-901 3 disc changer. Out of the blue, the unit will no longer accept the cartridge when inserted. When the unit worked correctly I could feel the unit accept the cartridge and then begin to load the cd. Now it feels as if the mechanism that grabs the cartridge is not present. There is no click and grasp, the cartridge is left suspended. Anyone else run into this problem and/or have a solution. Is there a manual eject procedure or reset that could be employed? Thanks for any information you can provide!
PS I have searched the archives for a possible solution. While this post http://forums.swedespeed.com/zerothread?id=47781 explains the problem, no answer is provided.
PSS Not exacly sure what the cure was, but I disconnected all connections to the 901, removed the top plate and probed all visible mechanical components. Reconnected everything again and voila. Everything functions correctly.
Modified by charltonhundley at 8:33 PM 4-17-2006
Modified by charltonhundley at 7:59 PM 4-18-2006
1 - 1 of 1 Posts
