1 - 8 of 8 Posts
· Registered
Re: Sat Radio Antenna Picture? (Edisto3)
Do you mean ANY sat antenna or the Volvo kit antenna?
Here's a pic of an xm antenna on my S80:
And here's a pic of my roady2:
Tim
· Registered
Quote, originally posted by Edisto3 »
Can you repost the pic of the antenna? I just need to see what it looks like when it is installed above the rear glass. Thanks
I'm confused...can you not see the antenna in the first pic? The "tail" of it is just routed under the rubber watherstripping, and then down the side of the window and then into the trunk.
Luke, I think it was you that has a pic describing this complete with "lines" on the pic that trace the path of the antenna wire...
Tim
· Registered
Re: Sat Radio Antenna Picture? (t6tim)
Quote, originally posted by t6tim »
Tim
Yeah, here it is. Let me know if you want the ones of how I routed it through the car. Also, since I took the picture I have moved the attenna closer to the back of the car so that less cable is exposed. So it now looks just like Tim's.
1 - 8 of 8 Posts
