Safe Max boost level on V70R
851 views 3 replies 4 participants last post by  Rues R
Hi Guys
Just wanted to get your views on what you would consider to be the safe maximum boost level for 2004 V70R.. I want to get as much from the car boost wise as I can without putting the block at risk!
My car has..
Bell FMIC
Ferrita 3" DP
Cat Back Exhaust system
High flow panel air filter
IPD HD TCV
R Kelly CAI
IPD/MTE Stage 2
Thanks in advance of your replies
Ian
Re: Safe Max boost level on V70R (burchi)
SAFE?
21 or so.
Just make just your ECU program is correct and bleeds off the boost a bit once it spikes
Re: Safe Max boost level on V70R (JRL)
Mine with a similar setup hits about 21-22psi and then tapers down
