1 - 20 of 23 Posts
The D5 will be with automatic gearbox and AWD, while the D4 will be FWD and manual gearbox.
I disagree on all points but I await independent tests to be certain. I note the lack of any T8 competitor.
The next gen E Class and 5 series will both have plug in hybrid capabilities pairing a 2liter 4 cylinder with electric power. Probably not with the split setup that Volvo uses, since both of those are RWD based.
Only the D5 somewhat lags compared to rivals, I suppose its due to the huge weight penalty that the S90 carries with it
Very likely indeed, given non-plugin 5-Series and E-Class hybrids have been sold for years. And you are correct about the layout. The I8 is the only BMW with a Through-The-Road (TTR) hybrid layout very like the T8, though turned 180 degrees. I doubt station wagon versions of either German sedan will be possible though, given the big battery on top of the rear axle. The PHEV versions of the GLE and X5 both have packaging problems, despite their height.
Love it! Same obsession before buying the XC60, all happening again!
with right price, a winner.
Any details about dimensions please, and would Australia get it from China factory?... estimate price comparison
Yeah, S90 is one heavy sedan... 350hp isn't a lot for a 1800-2000kg car. That's a mind boggling size.
So, do you think that your V70R is...weak?
I've driven the XC90 D5 AWD a few times, never felt it lacking in anyway. I must say I was quite surprised how powerful it was, it doesn't feel like a 2.0, probably because of the broad power range.
My comment was comparatively speaking, looking at the performance data chart above. In any case everything is relative, what may seem adequate to you and me may not be at all for others. Besides, Volvo is taking on the best with the S90, you dont want "adequate", you want the flagship to be authoritative in its power delivery. The T8 is a great example; a powerful diesel must follow IMHO.
The main problem of the S90 is its huge weight penalty, a current 520D is more than 100kg lighter, and the next gen 5 series is to be launched in 2016, like the S90, it will use carbonfiber, so the weight difference will probably be at least 200kg! Weight saving is crucial nowadays, its too bad that volvo missed the boat here. I do not foresee the S90 winning any comparison test against its rivals with such mass, which will affect every aspect of its dynamic abilities; hopefully it will at least translate into upsides like best-in-class NVH, which I also doubt...
But how does carbon fiber crash?
The VR doesn't make that much power and it's pretty heavy... The gearbox makes it feel fast because you're in boost really quick. It's 300hp does do the job and it's only 1700kg and AWD. The diesel is making 220 and weighs 100kg more in the lightest configuration. The VR is also a wagon... And it weights 100kg more than an S60... The V90 is going to be slow is the S90 is pushing 2000kg.
published already. there is a pdf on a UK site posted in this forum but I need to search again.
Sent from my SD4930UR using Tapatalk
How is that possible that new S90 D4 fwd weight 1800 kg. For example current S80 D4 (same enigine as in S90) weight 1700 kg. Isn't Volvo said that new SPA platform safe about 100 kg?
I am wondering how much will S90 awd D5 weight +2000 kg, that is almost in XC90 category.
Probably 100 kg of wire alone for all the technology :confused:
The V70R weighs 3,800 and almost 3,900 with the automatic (which was a not so ideal match with that engine). It performed well. The S90 and V90 will be similar in weight but with way more advanced engines and a much better automatic transmission, not to mention with an AWD system that will provide better traction.
These cars will not be slow.
Don't expect the next 5-Series, or any other competitor to be significantly lighter than the S90 in the real world. German car companies (and Jaguar/Land Rover) are notorious for quoting DIN or EU weights which are ALWAYS 5% to 10% lighter than reality.
Compared to the XC90 the S90 is about 0.5 inches longer, 2 inches narrower, 2 inches shorter in wheelbase, about 10 inches lower and 10% lighter. The S90 T8 is 2.15 tons, as against the XC90 T8's 2.35 tons, and is claimed to reach 62 mph in 5.2 seconds rather than 5.6 seconds, for example.
1 - 20 of 23 Posts
