1 - 2 of 2 Posts
I have a 1999 S80 t6 and when you start the car (No matter if the car is warm or not), it idles below 400 rpm or doesn't start. When this happens I put the car in neutral and it still won't idle up. Eventualy the car starts fine. After the car is started it runs and drives fine. I have replaced quite a few things and I am at a lost point with the car.
Things I have replaced
-Siren module
-Steering Column Lock
-ETM
-Battery
-Gas cap
The only code I am getting is for a EVAP system
With the car it is almost like it is not getting the right fuel/air mixture when you first start the car. Thank you for your time and help.
You replaced the Electronic Throttle Module? How much did that cost? Did you do the work yourself?
1 - 2 of 2 Posts
