Hi,<p>1999 S80<p>How do I get the A pillar covers off? I need to reglue the fabric.<p>Also, how do I get the lower dash panel off? I need to access the steering column to diagnose a rattle coming from behind the steering wheel. There are two parts. The lower is easy, two nuts and pull the clips at the corners. But the main portion of the lower dash has me baffled.<p>Thanks
Re: S80 Interior Trim Removal (PMossberg)
To remove the A pillar cover i believe you just pull it away from the pillar and once it unclips just pull up toward headliner to get the bottom piece out of the dashboard. You have to get a good grip on it by putting your fingers over the top and behind it a little. The problem is that even gluing that fabric back together isn't going to help unless you clean it thoroughly and reapply that foam like glue.<p>I tried the same thing with 3Ms extra strength adhesive and it didnt stay on long with the heat. I just got a whole panel.
