I am curious if anyone has ever "tapped" into the signal from the factory power antenna using a flexible/soft wire antenna to relocate the signal? Main reason for doing this is that I want to disable the power antenna and relocate a flexible antenna to the top of the rear windshield.
This is on a 2000 S70.
You should be able to unplug the power antenna coax and
find a standard antenna connector at the end of the cable.
The aftermarket antenna should be able to plug right in.
Mounting the new antenna and running it's cable may
present a little more of a challenge... Good Luck!
Thanks for the help. I'm not too worried about the routing of the new antenna, I was just curious if there was a special procedure to "tap" into the existing signal.
