1 - 6 of 6 Posts
Greetings,<p>I am the owner of a 1999 Volvo S70 and have recently been having problems with the coolant light coming on. I have checked the coolant reservoir many times and it is properly filled. <p>About four months ago I had my car's AC compressor replaced at the dealer. I never had trouble with the coolant light coming on until this repair was performed. Also, the coolant light does not stay lit constantly. It seems to light up when I am driving over bumpy side roads around town. Could this be a loose sensor?<p>Just looking for some initial feedback before I take the car back to the dealer. Hopefully this isn't something serious or costly!
Re: S70 Coolant Light - On but Coolant Not Low??? (BdoUK)
you probably have a faulty sensor in the coolant reservoir...lift up the <br>reservoir (not hard) and you should see a wire to the sensor...wiggle it and the light will probably go on and off ..this should verify if thats the problem
You sure it's not the windshield wiper fluid level low indicator lamp? These lamps look similar. If so, simple solution is to fill your wiper fluid tank.
It is definitely the coolant light. I lifted the resevoir earlier and pushed the wire up a bit. It looks like it might be a little loose at the bottom of the tank. The light isn't currently coming on but I have a feeling it will again once I start driving on the wonderful Lexington streets.<p>Thanks for the help!
Re: (BdoUK)
I had this happen to me on a long drive. Was confused, because I knew the level was fine earlier. Then, I worried that the water pump was just going out or some hose ruptured. I kept a careful eye on the temp gauge.<p>After after a few minutes and slowing down to pull off on the shoulder prior to entering another stretch of highway, the light went off.<p>My conclusion is that the sensor simply got lodged to the side during a turn or some movement and failed to return to the top, hence the light. I don’t know if there is some delay built in to eliminate false triggers.<p>At any rate, the coolant level was slightly above maximum.<p>regards,<br>MAJ
No sensor floating in these tanks. The electrical connection is made through the coolant if I remember correctly. So, if the sensor isn't covered with fluid it will show low level...this is of course unless the sensor wire or sensor itself has a short.
1 - 6 of 6 Posts
