1 - 19 of 19 Posts
S60R / V70R (P2) Modification & Repair Index
Table of Contents / Glossary
Exterior
  • Exterior Lighting
  • Bumpers
  • Grilles
  • Emblems & Badges
  • Paint & Trims & Mouldings
  • Lips, Skirts, Spoilers & Winglets
  • Mirrors, Windshield & Windows
Interior
  • Gauges
  • Manual Shifters
  • Leather Maintenance & Conditioning
  • Keys / Remotes / Locks
  • Interior panels & consoles
  • Interior Lighting / Bulbs Replacement
Electronics
  • Electrical & Wiring
  • Dice / VIDA Software
  • Headunits, Car PCs, & Media Connectivity
  • OBD II
Suspension & Chassis & Handling
  • Sway Bars
  • 4C Struts, Springs, & Coilovers
  • Endlinks, Bushings & Engine Mounts
  • Strut Bars, Chassis support
Brakes, Wheels, Bolts & Spacers
  • Spacers & Bolts
  • Rotors, Pads & Calipers
  • Wheels Fitment & Popular Wheels
Engine - Under the hood
  • ECU / Tunes
  • Motor / Crankcase
  • Ignition
  • Intakes & Filters
  • Exhaust & Downpipes
  • FMIC & Cooling
  • Turbochargers
  • Water Injection
  • Oil Cooling & Catch
Transmission & Drivetrain
  • Clutch
  • Axles, Shafts & Hubs
  • Angle Gear
  • Haldex
Notable Builds
  • High Powered & Output builds
  • Popular & Cosmetic Builds
Documentations
  • Volvo Documents
  • TNN Full List
  • Owners Manuals
  • & other PDFs
Vendors & Companies
  • Vendor Feedback Thread
  • Aftermarket OEM Parts
  • Company List
Change Log
Dec 2016
  • Added Full LED Conversion Thread by theshadow27 to both Exterior and Interior Lighting sections
Sept 2016
  • Added 'How To' for Drive Axles and Hub Guide
  • Added DRL Load Resister for LED Bulbs
  • Fixed Fuel Sensor Link
  • Added Trav R's S60R
This is a work in progress. After breaking it up, some sections look a little lacking. This is good and bad, I need some volunteers and helpers to populate some of these sections. I can't remember and neither have I read all the topics and interesting threads out there.-DevolvR
Find something awesome on the forum and it's not part of this?
Click here
Exterior</a>
Exterior Lighting
How to Change Headlights and Fog Light Bulbs
Headlight blackout
Euro headlight mod
How to DIY clear sidemarker bulbs
DIY Install DRL Load Resistors on P2 S60R
EuroSpec R Headlight Conversion - R Kelly in his Adventure in R Lighting
VIDA - Here's how to adjust DRL Lighting Modes
DDM HID Foglights - H3 Installed Beam Pics
EuroSpec City Lights - 5K Bulbs
Full Exterior LED Conversion: Signal Lights, Puddle, License Plate, DRL/Running Headlamps & Interior
Projector retrofit guide
R Headlight Projector Retrofit with CCFLs
Dual Rear Fog Lights
LED Tail Lights - PWM Controller, Full Brake light conversion
LED Taillights - PWM Controller , Brake Light , Contour Line
LED Taillights - Position light Contour Lines
Jewel Taillight Conversion - 2004 to 2005+
Bumpers Covers
How to: Remove Front Bumper & Replace Foglight Bulbs
Grilles
Elevate hood grill install
Paint, Trims & Moldings
Roof trim removal & Roof & Windshield Side Molding replacement
Painted trim on 04 > 05 Body Color (Jstro)
Badges & Emblems
TakSpeed Badge
Swedish Motorsport Badge - Cut by Caschy (Juve021)
R Badge
R Shield Badge - Juve021
Front
VST Add-on Front Lip
SEAT Cupra Lip DIY
Spoiler
CFWerks VST Style Front Lip
CFWerks Roof Spoiler
CFWerks PCC Spoiler - Trunk Panel Replacement
Custom M3 CSL Spoiler - PCC Style
Power Folding Mirror Install Guide
Rain Sensor Repair
Window Glass Slider Clips Replacement Guide
Interior
Boost Gauge
Boost Gauge Know-How I
Boost Gauge Know-How II
Boost Gauge Know-How III
Boost Gauge Know-How IV
Boost Gauge Know-How V
Boost Gauge Know-How VI
Boost Gauge Know-How VII
Boost Gauge Know-How VIII
Various Gauge Know-How I
Various Gauge Know-How II
CF Werks Door Pod Install
Gauge Pod Fabrication - Center Speaker I
Gauge Pod Fabrication - Center Speaker II
Gauge Pod Fabrication - Center Speaker III
Gauge Pod Fabrication - A Pillar I
Gauge Pod Fabrication - A Pillar II
Gauge Pod Fabrication - A Pillar III
Gauge Pod Fabrication - Dash Cubby I
Gauge Pod Fabrication - Dash / Fitzy Mod I
Gauge Pod Fabrication - Dash / Fitzy Mod II
Gauge Pod Fabrication - Dash / Fitzy Mod III
Shifters
Short Shifter - TWM Transmission Pulley
Short Shifter - SNABB Shifter Rod
Shift Knob - TWM M1 Abrams
Leather Repair & Maintenance
Leatherique I - Rejuvinator Oil
Leatherique II - Pristine Clean
Leather Fix - Atacama Re-Dye
Leather Fix - Nordkap Re-Dye
Leather Fix - DIY Gobi Re-Dye
Interior Panels & Console
Fix Glovebox Rattle
How to fix a broken center console door
Center Console / Cup Holder / Armrest Swap - 2004 to 2005+
How to replace spaceball with leather boot
CCM & HU Bulb Replacement / Swap
Interior Lighting
Full LED Conversion Thread S60/V70
LED Interior Lights - Dome Lights + Foot Wells
Key / Remote / Locks
Ignition Lock Cylinder Replacement
How to repair a switchblade key
Misc Interior & Accessories
Turn signal switch install
How to adjust your sunroof
Sunroof rattle repair
Blower motor removal
Replace window sliders
Calibrate window limits
How to get through the firewall
Radio and center console removal
Replace cabin air filter (video)
Climate control bulb replacement
Insulating VR tailgate
Aluminum Sport Pedals
Full size spare
Engine / Under the Hood
ECU / Tunes
How to Reset the ECU
RICA vs BSR vs Stock Comparison
Motor
Timing Belt Replacement - Phuz
Replace PCV Breather & Throttle Body Cleaning (vLGrok)
Ignition & Fuel Delivery
R Spark Plug Change Guide
Spark Plugs - OEM vs Aftermarket I
Spark Plugs: OEM vs Aftermarket II
Spark Plugs: OEM vs Aftermarket III
Spark Plugs: OEM vs Aftermarket IV
Spark Plugs: OEM vs Aftermarket V
Spark Plugs: OEM vs Aftermarket VI
IPD HDR Coils
IPD HDR Coils II
VST Ignition Coil REV Kit
Fuel Injectors I
Fuel Injectors II
Fuel Pressure Sensor - How to replace
Cold Air Intakes & Filters
SNABB Intake Installation
SNABB V2 Intake
R-Kelly Ram Air - Cold Air Intake I
R-Kelly Ram Air - Cold Air Intake II
R-Kelly Ram Air - Cold Air Intake III
R-Kelly Ram Air - Cold Air Intake IV
R-Kelly Ram Air - Cold Air Intake V2 - New Scoop - *IPD CAI
AEM Dryflow - Open Air Box
Exhaust & Downpipes
IPD Oval Tube Exhaust for 04-07 S60R/V70R
EST DP & Exhaust
OBX DP & Exhaust
Custom Dual Exhaust - Quad Tip w/o Bodykit
Custom Dual Exhaust - Quad Tip No mufflers w/Bodykit
Exhaust - R Kelly's Comparison (dated with discontinued exhausts - for info only)
FMIC & Cooling
HOW TO- Replace Thermostat (qwkbrk)
HOW TO- Replace Radiator (vLGrok)
VIVA FMIC Install & Review (tomedkaz)
DIY FMIC and Charge Pipe (mullen1120)
Front Mounted Intercooler I
Front Mounted Intercooler II
Front Mounted Intercooler III
Front Mounted Intercooler IV
Front Mounted Intercooler V
Front Mounted Intercooler VI
Front Mounted Intercooler VII
Front Mounted Intercooler VIII
Phuz FMIC Install
AEM Meth Install
Aquamist Water Injection I
Aquamist Water Injection II
Aquamist Water Injection III
Aquamist Water Injection IV
Turbochargers
ViVa performance CBV upgrade install
Turbo TalkI
Turbo Talk II
Turbo Talk III
Turbo Talk IV- DE V70R's upgrade approach
Turbo Talk V - Discussion on Valves: Blow-off, Diverter, Compressor Bypass
Turbo Talk VI - Compressor Bypass Valve
Turbo Talk VII - Turbo Control Valve Explanation
Turbo Talk VIII - ECU Programming, Wastegate Setting Relationship & Impact on A/F Ratios & Boost
Turbo Talk IX - 450bhp?, Pressure vs Flow, & More
How Do I get 400-450 Horsepower?
ECU, Downpipe, & A/F Ratio Relationships
Water Injection
Discom I - Water Injection & Stuff
Discom II - Pushing Limits & Blowing Engines
Discom III - Engine Rebuild
Discom IV - BOV
Oil Cooling & Catch
Oil Cooler
Oil Catch Tanks
Hi. Newbie here, links for part numbers/ tech manual partial are 404. Do you have links or knowledge of where I can get full parts lists/specs and full repair manual for v70r 2004?
DevolvR: Fixed. No, unfortunately I don't. Try posting a thread asking if anyone has information regarding this. As for a Parts catalog, Tasca Parts Online may be one of the most extensive parts/price lists available. http://www.tascaparts.com/
VIDA is what you're looking for... Which has the repair manual and parts catalog - though Tasca is more accessible for parts and obviously you can see prices there.
A LOT of links have dead pictures in them, which makes some guides completely useless. :(
I am happy to host images (forever) for anyone who asks, in order to keep these threads alive and useful!
Is there a thread somewhere here about replacing the TF-80SC valve body?
Hi. I need to replace the waste gate on my 2005 V70R M6, but I'm stumped where to find exactly what turbo I have. Any help would be immensely appreciated, Thanks.
Well. The part/serial number should be on it, that's hard to see though. The Rs i believe all have the same Turbo stock. With the only difference being the v-clamp that connects the turbo to the OTE pipe.
Sent from my LG-H810 using Tapatalk
S60R / V70R Modification & Repair Index
Submitting this here because I couldn't find a comprehensive write-up and since the R sub is more active.
I put my sport kit side skirts on a couple days ago in about 2 hours, I was able to re-use most of the clips and substitute with some of my spare junkyard clips but if you can't here's what you'll need:
- rivets for the wheel wells: oem is 10mm head with 6mm shaft (before expanding)
- Push pin retainers for the undercarriage
- Either round or rectangle retainers for the sills
For tools I used:
- H4 hex bit to disengage the plastic push pin rivets securing the undercarriage
- flat pry bar to remove the metal rivets in the wheel well (and to extract the plastic push rivets) since I don't have whatever tool removes rivets
- T25 to secure the wheel well ends with some interior screws from my junk yard stash since I didn't have big enough rivets to replace the originals
Removing the stock rocker panels:
Pop these bad boys off by hammering the H4 into the center to disengage the pin and the claw end of the hammer to pinch and yank them out.
For the pins that I pushed too far and got stuck in the metal of the car (you'll know what I mean when you're down there) I used tiny drill bits to poke around inside and drag the pin out of the hole.
Pry and pry again, the front ends have 1 on the side and 1 on the bottom, rears have 2 on the side and 1 on the bottom. My 04 skirts did not have the bottom hole for the mud flap / wheel well liner to anchor to so I didn't add one, so far nothing has fallen off.
Installing the sport kit skirts:
Not sure about the 05-07, but my 04 skirts each only needed 2 door/trim fasteners (front and rear), and a peg attached to the skirt slotted into one of the holes beneath the b-pillar to hold it in place while you shove the skirts onto the fasteners (or attach the fasteners to the skirts and just pop the whole thing in).
Since I was able to re-use the push pin fasteners I placed 5 underneath on each side. There are holes for 8 but really 3 was enough to feel secure.
Now since I didn't have rivets big enough to fill the holes to secure the ends of the skirts to the mud flaps / wheel wells, I used T25 interior screws, I had a ton left over from my dash/center console swap and these did the trick with no wiggle play or shifting. Another benefit of using the screws was that I didn't need to take any wheels off for the install, I just used the bit stuck in the little socket adapter and turned by hand.
Rear left aide
Front driver side, from the perspective of the ground to show the semi-hidden bottom rivet placement.
The results:
1 - 19 of 19 Posts
