reference:
http://forums.swedespeed.com/zerothread?id=133370
Well, the journey is coming to an end as the LED tails are done (for now) and 90% installed (just have to run alittle wiring and install load resistors or figure out shunts to cancel bulb out warning messages).
Pics and vids:
http://tinypic.com/r/1zmcdmu/5
http://tinypic.com/r/2mnrvxz/5
And yes I know one rev. bulb is out! Also don't mind the flickering, its the PWM effect that the camera pics up (they really don't flicker). Actually, these pics/vids really don't do the LEDs justice, you have to see them in person as they look really good IMO!
All in all, I'm happy. Some points/advice/things I've learned along the way:
1) taking apart the tails isn't that difficult just time consuming and you must go slow or you will crack the lenses
2) cutting the plastic does make a mess (I used a combo of dremel with cutting wheel, razor blade and hacksaw blade (just the blade in the palm of your hand). I made slits all around the back of the tails with the dremel and then used the hacksaw blade to actually cut out the back from the lense. The razor blade comes in handy on the bottom of the tail where you slowly and lights just pry apart the lense from the plastic weld.
3) might have done the LED patterns differently but I'm all about unique and I think they def represent that
4) sniffing soldering fumes is not good
Anyway, if anyone is wanting to do this and needs some help/questions answered, let me know. I also have like 35 leds left over if anyone wants to purchase them
Pics and vids:
