1 - 6 of 6 Posts
· Premium Member
quote:
Originally posted by e1618978:
I'm starting to really hate the look
of the shifter in the S60R. Is this
shifter in any other Volvo? How likely
is it that I will be able to replace
it with a conventional leather shift
boot?
Get the car first
and then we 'll talk about a swap...
Yannis
· Registered
boot?
Once you hit the 7700 RPM limiter and discover that you can change gears in no time you want it to be ALU then it already is.
After 5 minutes you do not notice it anymore but a lot of people think it's an AT or a sequential GB.
· Registered
quote:
Originally posted by The_one_n_only:
Why not just the regular S60T5 space ball, why the R space ball?
If you want to know about the previous discussion regarding the S60T5's space ball retrofit, go to C70 section and search for the topic in the history.
Because the one from the R has the 6 in it.
Makes it real ugly
[This message has been edited by Johann (edited 07-19-2002).]
· Registered
I hadn't seen any recent Volvos, so I
didn't know that the S60 T5 had the shifter
as well.
All of the areas down there on my 850
get full of grime and grit - is there
any problem with stuff getting caught
under the lip and either scratching
the surface, preventing a shift, or
seeping down under the cover into the
transmission? On my 850, that area is
right under the coffee holder, for
example.
1 - 6 of 6 Posts
