S60R built motor??
959 Views 11 Replies 7 Participants Last post by  CKAVolvo
after months of research I’ve narrowed it down to three options 1) buying a 4t3/9 and swapping the r oil pan and head and calling it a day 2) the same as option 1 but swapping in the crank and rods from the 4t4 for the 93.5 mm stroke 3) or throwing k1 forged conrods wiesco forged pistons and the 4t4 crank for a built 4t3/9 with the better 93.5 mm stroke. If you guys could let me know what ballpark hp/tq numbers i could make reliably with each setup that would also be great
1 - 12 of 12 Posts
I’ll also mention that i want to run a big turbo setup and am aiming for ~500-600bhp but i would still be open to getting the ipd 4t4 turbo upgrade if those numbers aren’t attainable with any of the setups I mentioned
A tuner like Contrast or Rolling Motors would probably know specifics on numbers. Or a lurker like @dougy lol
Sent from my Pixel 6 using Tapatalk
450 o 500 is reasonable to do. Above 500 takes some patients and time. Not many good options for intake and Exhaust Manifold. Milletech is the go-to but aven heard back from Nikola, Trying to get some titanium exhaust tips
I think that with any of those options you can get to 500whp with stock intake/exhaust manifolds. I would go the forged rods and pistons route personally just for added insurance.
Sent from my SM-G998U using Tapatalk
Doesn't re-volvo sell an R exhaust manifold with a T3 flange? And also doesn't Milletech make high-performance
intake and exhaust manifolds?
Sent from my Phone 2 using Tapatalk
I'd go the Dougy route, and weld/machine an adapter to the stock manifold to run a regular T3 turbo. Look up his build thread, tons of great info.
Like this: GT3582R T3 exhaust housing with 45mm WG hole &amp...
Reactions: 2
I'm sure they do, my point is that for 500whp you don't need an equal length exhaust manifold. That level of power can be reached with a stock manifold or a Japanifold. It may definitely require modification if the flange depending on your turbo. Mine are vband flanges welded to the manifold flange.
More of just bringing up the manifold options I know of
Reactions: 1
3
The top of the line Milletch will cost as much as some whole cars, But they are well designed
Automotive tire Motor vehicle Automotive design Automotive exhaust Rim
1 - 12 of 12 Posts
