Rad is leaking and need to replace.
Can anyone please confirm if S60 rad will fit S60R?
Found OEM Nissen for much less then dealer wants, but does not list the R model.
Thanks!
The Nissens radiator OEM for R is nice. Mine has held up for four years, after two Volvo radiators split the lower passenger side on the seam after about 20 months each. However, USE THE VOLVO HOSES kit. The Volvo hoses have serrated connectors that hold more adhesive, and will stay attached, and not blow off under extreme pressure. I had a radiator hose blow off and cost me a rebuild (see long thread elsewhere). Good luck!
