After some analysis of the wheel and tire options for the S60, it appears that the diameters of each of the options is different enough to yield an almost 10mph delta from the smallest combination to the largest. I was wondering if anyone knows whether the speedo is recalibrated depending on which option is selected? If so, and aftermarket wheels are purchased, is it that easy to recalibrate the speedo later?
Most speedometer shops or your dealer should be able to recalibrate your speedo pretty easily. I don't think that'd be a problem.
http://www.tirerack.com should have a calculator that will help you determine the right size tire with an upgraded wheel to keep your speedo accurate.
Thanks George. I imagine if it's so easy to do, that Volvo regularly tweaks the speedo settings depending upon which wheel/tire combination you select.
