1 - 2 of 2 Posts
Looking for info on fluid change only info i havr=e right now is vehicle is s60 2.4L cust wants to have fluid changed. ? Are these trans like the VW's supposablynon servicable and complicate draing and fill any imput greatly appreciated. :cool::cool:
fromthewww...
...it took 14 quarts. The easiest way to flush is pull the lower hose from the cooler on the driver's side of the radiator. Put a short piece of 1/2" clear hose over the end fitting and start the motor until the fluid flow slows. Fill trans and repeat. The lower fascia comes off with two bolts then let it roll down and pull back. There are "tabs" molded into the fascia that slide into slots in the bumper.
George Dill
1 - 2 of 2 Posts
