1 - 2 of 2 Posts
I'm pretty unhappy with handling over 160 KPH on almost any surface or at lower speeds on really twisty roads. I find that I get the wheels rubbing on the well liners on tight aggressive lower speed corners or on dips at higher speeds. I also notice a lot of "float" at speeds of about 200 KMH or above. I want to make some upgrades to diminish or eliminate (if possible) these tendancies. What would be the most important upgrades in order? Springs, Dampers, anti-sway bars? I notice that product selection seems pretty limited in all these areas for the S60 at this time. Eibach and TME/IPD offer springs, Koni Sports for dampners and IPD say that anti-sways will be available in the June 1st catalog and that seems to be about it AFAIK. I don't want to add downforce through skirts or other areodynamic means. I also don't really want the car to look "slammed" although I am prepared to lower it with springs...speaking of springs...what about camber adjustment? I have a 2001 T5 without the sport suspension option (I don't think it was available in Canada at the time). Thanks for any help.
Unfortunately, the Sport Suspension would have probably done the trick. My '02 T5 has it and I found it better than the regular susp with the Tethys wheels. I think the springs are only slightly firmer but the susp has more to do with the roll bars. The regular suspension has a 23.5mm front bar and 19mm rear. The Sport has 24mm front/21mm rear and recalibrated F/R shock absorbers, which sounds like what you need.
1 - 2 of 2 Posts
