Has anyone installed a sub in the S60?
I know that the amp is under the driver's seat and I can get a harness adapter to splice into meaning the original cabling is untouched.
What I'm not sure about is running the cables, especially the power cable. In my C30 you could remove the glovebox and behind the fuse box there was a giant grommet that you could run the power cable through. Is this the same on the S60?
Anyone with pictures of their install would be good too!
