My S60 Polestar for sale.
The car I bought new at the Warsaw House VOLVO Salon on May 29, 2017, since then I am its first and only owner. There is currently no second copy from the Polish showroom for sale, with a full history, so well-kept and maintained. The car is still under warranty valid until May 29, 2022. The car is in perfect condition, no accidents, serviced only at the VOLVO Dealership in Warsaw by a dedicated mechanic. Immediately after leaving the showroom, a quartz coating was applied to protect the car's paintwork. Pedantically well-kept, now has a mileage of 96,000 km and the oil at the VOLVO Dealership has been changed for the 10th time. The car even had the gearbox oil changed. Naturally, the car, apart from frequent oil services, had all the required inspections and replacements of elements that resulted from the service schedules for this model. Everything is available for inspection, invoices, and the entire history to be reviewed and confirmed at VOLVO Dealership. The car without any unnecessary modifications and alterations, only two things have been improved. Do88's inefficient IC. A significant increase in power compared to the factory one without any additional modifications, the car after this modification shows 400KM on the dynamometer. 2. Upgrade of the brakes - made with the help of WRK brakes, where dedicated rotors with a diameter of 380mm were created, a different model of a brake pad with a higher tread was used, a changed floating system, all brake lines changed to a steel braid + different brake fluid. Currently, in the best-performing setup: front 380mm WRK brakes floating discs, ferodo DS2500 pads. Rear brembo OE brake disc, yellow stuff EBC pads).
Before the sale in the car, the following things were done:
• Inspection and oil change at VOLVO Dealership.
• All brake discs and pads replaced with new ones • New quartz coating preceded by a two-stage paint correction, thanks to which the car looks like new
• Installed new summer tires PILOT SPORT 4S (possibility of buying the car with a second set of winter wheels on 19 ”BBS rims with practically new winter tires). The car can be seen in Warsaw, before buying it can be checked at any authorized VOLVO service point.
Wheel Tire Car Vehicle Automotive side-view mirror
Vehicle Car Head restraint Car seat cover Motor vehicle
Car Vehicle Speedometer Motor vehicle Gear shift
Car Gear shift Speedometer Vehicle Motor vehicle
Tire Wheel Car Automotive tail & brake light Vehicle
Automotive design Motor vehicle Gear shift Steering wheel Personal luxury car
Tire Wheel Automotive tail & brake light Car Vehicle
Wheel Tire Car Automotive tail & brake light Vehicle
Tire Wheel Car Land vehicle Vehicle
Vehicle Motor vehicle Car Automotive design Car seat cover
