Hi Everyone,
The maintenance section reads:volvo s60 engine/transmission timing gear check for leaks at 20k miles.
Does anyone know what the meaning of leaks is?
I am a bit concerned since I have 30k miles.
Check hoses.
What about the timing gear check? That sounds like the timing belt. Maybe its something simple like open the timing cover and verify the belt is fitting properly on the timing gear?
Buy it the car was running rough you would know the timing belt/gear is offset.
Most checks are visual inspections. Course if theres a problem or keak. Volvo techs will delve further.
