1 - 20 of 50 Posts
Hi, This is my first time sharing my modification info. I hope to share mod. info and exchange mod. info with everyone here.
My Project S60 2.3T Year 2001 B5234T7
Objective 450 HP on Wheel
Modification Info.
Stage 0
1. Custom FMOG (Oil Gear)
2. Replace New Drive Shaft
3. 330mm brake rotors
4. Overhaul Transmission
5. New Coil Pack 5 Pcs
6. New DENSO IRIDIUM POWER IK22 5 Pcs
7. OEM Water Coolant Reservoir
8. OEM Power Steering Reservoir
Stage 1
1. Custom high flow Exhaust 3 inch (Catless)
2. Custom high flow intake 3 inch with Bigger 4 inch HKS mushroom filter
Stage 2
1. Custom Downpipe 3.5 inch
2. R Manifold
3. Upgrade Intercooler FMIC
Stage 3
1. Turbo Solenoid Valve Boost Control Pierburg
2. <a href="https://forums.swedespeed.com/showthread.php?598355-Swap-TD04-to-K24-turbo-Hybrid-By-Akeker&p=7313561#post7313561">Swap TD04 to K24 turbo Hybrid Inducer Dia. : 58 mm Exducer Dia. : 75 mm Blade 8+8</a>
3. Westgate Mamba Stage 3 with Spring Orange support 26 PSI 1.8 BAR
4. Blow Off Valve (Greddy FV)
5. water-methanol injection system Snow Performance 210 Injection Kit
6. <a href="https://forums.swedespeed.com/showthread.php?597791-Custom-Mass-Air-Flow-By-Akeker">Custom big 4 MAF</a>
7. Fuel Injectors 650cc BOSCH EV14
8. Fuel Pump Aeromotive 340 LPH Stealth High-Output In-Tank Electric Fuel Pump EFI GM 11569 Compatible E85
9. Custom Ram Air Induction Plate Kit For Pressurizing the air filter box
10. Defi A1 & ZD Gauge set (Water Temp, Volt, Oil Press, Oil Temp, Speed, Tachometer, Time Attack 0-100, 0-200 KPH)
11. AFR Gauge AEM 30-4110 AFR 52mm Wideband O2 UEGO Controller Gauge Air Fuel Ratio 4.9 LSU
12. Return Fuel System (Nuke Fuel Surge Tank with 2 internal Walbro GST450, Nuke Fuel Rail , Aeromotive Regulator 13305 (35-75 PSI) , Upgrade Fuel Line Teflon Braided Line E85 PTFE )
13. Custom Intake Manifold
Tuned ECU Info.
<a href="https://forums.swedespeed.com/showthread.php?599079-Tuning-software-with-Hilton-Stage-3-By-Akeker">Tuning software with Hilton Stage 3</a>
Add-Ons: Automatic Transmission Torque Limiter Removal – Remove the first and second gear torque limiter from automatic transmissions.
Catalyst Delete (Stage 2 and up only)
E85 Tuning
Fuel Return System Tune
Next Step
1. High Energy Ignition Coil
2. Rebuild Engine Forged Rods, Forged Pistons
3. Convert from Automatic trans to Manual trans
4. Boost Target 3 Bar
5. Plan upgrade to bigger New 6466 Turbo, Divided T4 1.00A/R turbine housing , 4" inlet .70A/R compressor housing
Exterior
1. Upgrade front bumper S60R
2. Head light S60R
3. S60R body kit
4. Brake Bambo S60R
5. Heico Wheel 18 inch
6. Suspension System Bilstein B6
Discussion Starter · #2 ·
My FMIC, Air Intake, HKS Filter
<img src="https://i.ibb.co/xqS1DSz/LINE-P20190412-15260551.jpg" alt="LINE-P20190412-15260551">
<img src="https://i.ibb.co/sCpF91W/LINE-P20190412-15263044.jpg" alt="LINE-P20190412-15263044">
Just finished install Defi A1 Guage
<img src="https://i.ibb.co/1JcmnZy/IMG-2672.jpg" alt="IMG-2672" border="0">
<img src="https://i.ibb.co/HKQS0HV/IMG-2677.jpg" alt="IMG-2677" border="0">
<img src="https://i.ibb.co/4dzvSSn/IMG-2676.jpg" alt="IMG-2676" border="0">
<img src="https://i.ibb.co/njPhsMs/IMG-2675.jpg" alt="IMG-2675" border="0">
<img src="https://i.ibb.co/LQwMwKb/IMG-2674.jpg" alt="IMG-2674" border="0">
<img src="https://i.ibb.co/mhmP7b1/IMG-2673.jpg" alt="IMG-2673" border="0">
I got my stuffs from Nuke Performance. Cannot wait to make happen
<img src="https://i.ibb.co/mT4rTZh/IMG-3015.jpg" alt="IMG-3015" width="500" height="600"/>
<img src="https://i.ibb.co/X57VbN0/IMG-3014.jpg" alt="IMG-3014" width="500" height="600"/>
<img src="https://i.ibb.co/Y27rv65/IMG-3013.jpg" alt="IMG-3013" width="500" height="600"/>
<img src="https://i.ibb.co/s9JFtqF/IMG-3004.jpg" alt="IMG-3004" width="500" height="600"/>
Discussion Starter · #5 · (Edited)
Custom Intake Manifold.
<img src="https://i.ibb.co/kSv4HX6/IMG-3214.jpg" alt="IMG-3214" border="0" width="500" height="600">
Look Amazing how it look like!!!
<img src="https://i.ibb.co/nwNyqDs/LINE-P2019729-152407.jpg" alt="LINE-P2019729-152407" border="0">
Quite a build!
Discussion Starter · #9 · (Edited)
nice job :thumbup::thumbup: ... love that gauges setup!
Thanks. There's time attack function but I need to connect red wire [Speed Sensor]from DEFI to trap the signal from Volvo's speed sensor. Do you know where is the speed sensor location in the engine bay?
Quite a build!
Thanks, I've tried my best make my Volvo faster than BMW,Benz,New Honda Civic.
Discussion Starter · #10 · (Edited)
Just finished car wash
<img src="https://i.ibb.co/1f5Mrzq/My-S60-01.jpg" alt="My-S60-01" border="0">
Discussion Starter · #13 ·
My Back side view.
<img src="https://i.ibb.co/R0S52kY/My-S60-02.jpg" alt="My-S60-02" border="0">
Discussion Starter · #14 · (Edited)
My Engine Bay @ 28 Sep 2019
<img src="https://i.ibb.co/3BrQjkZ/My-S60-11.jpg" alt="My-S60-11" border="0" />
Discussion Starter · #15 · (Edited)
Test Pull Engine at idle. Hear a little sounds of blow-off valve.
<p>
</p>
Very impressive, nice work! I noticed your license plates where are you located?
Discussion Starter · #17 ·
Discussion Starter · #18 ·
Maintenance my exhaust at the RPT Shop.
<img src="https://i.ibb.co/R6PGCQ2/My-S60-12.jpg" alt="My-S60-12" border="0" />
<img src="https://i.ibb.co/jvSqknG/My-S60-08.jpg" alt="My-S60-08" border="0" />
Discussion Starter · #19 · (Edited)
Today, I do more job with steering wheel. it took me 6 hours to complete.
<img src="https://i.ibb.co/3mqjJJM/My-S60-13.jpg" alt="My-S60-13" border="0">
<img src="https://i.ibb.co/xhTzxSc/My-S60-14.jpg" alt="My-S60-14" border="0">
<img src="https://i.ibb.co/WzDCGzS/My-S60-15.jpg" alt="My-S60-15" border="0">
Discussion Starter · #20 ·
My custom 3.5 down pipe and 3 inch exhaust sounds
1 - 20 of 50 Posts
