Has anyone changed the cabin air filter or fuel filter in a 05 S40 T5? I was told cabin air is passenger side behind the glove box - No dice. Might the fuel filter be above the tank? I was hoping someone else has done this before I get deeper in my search.
The cabin filter is there if you have a RHD car. <br>Check the sticky for how-tos if you're looking to do anything else; for now, here's the air filter change:<br><A HREF="http://forums.swedespeed.com/zerothread?id=116825" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=116825</A>
Re: s40 T5 - fuel filter & cabin air location (turtle6981)
Cabin filter is on the left hand side of the vehicle whether its LHD or RHD (i pray yours is RHD). Once all under dash panels are removed look towards the center of the dash underneath. You'll see a black cover with 3 7mm screws holding it on, inside there is the cabin filter.<p>Most S40 fuel filters are in tank and the service interval is over 100k miles so odds are its not due to replacement on your vehicle unless you have failry high mileage. Check your service intervals in your owners manual.
