1 - 20 of 22 Posts
My GF advised me of a few issues since her new (to us) 2006 S40T5AWD. <p>Sometimes, maybe 10% of the time, when turning the car on, the temperature display will read a much lower value than actual temperature. I think it eventually rebounds to the actual temp., but something is askew. <p>Just yesterday, for the first time ever, neither the passenger or rear passenger window would go up. I believe they are on independent circuits so I am a bit baffled. From what she said, it stayed like this for 4 different trips/ignition cycles, and then it started working again. She tried from the driver door control as well as the controls at each of the windows.<p>Obviously the fuses are OK if they resumed operation, but maybe someone knows of these pending issues already and has an answer. I haven't had any luck through searches. Next step is to trace the wiring and explore the VADIS diagrams. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"><p>Is the temp sensor in the passenger mirror on these cars?
Re: S40 T5 AWD gremlins (phuz)
AFAIK, the sensor is around there. I remember a thread talking about it and he ultimately had to clean the sensors, but I can't find it for the life of me. HALP!
I found a massive PDF of electrical info in our cars (Where things are, wire colors, etc.). It may help you find what you need.<p>30 meg pdf: <A HREF="http://pliki.mojevolvo.pl/volvotechinfo/tp3978202_s40_v50_2004-_wiring_diagrams_section_3_39.pdf" TARGET="_blank">http://pliki.mojevolvo.pl/volv...9.pdf</A><p>From <A HREF="http://mojevolvo.pl/wiki/Volvo_S40" TARGET="_blank">http://mojevolvo.pl/wiki/Volvo_S40</A>. The web site is in polish, but the PDF is english.
FYI, most cars have to drive to 30 mph to get an accurate temp reading. I've read this in previous car manuals Havent read the volvo one, but I wouldnt guess it wouldnt be different...
Re: S40 T5 AWD gremlins (callmedoc)
my dealer said its the wiring harness in the driver door. the little things sticking out under you driverside merrior is the acutal senser. I also heard that cleaing the harness helps but i could never figure out how. it also effect window movement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>callmedoc</b> »</i></TD></TR><TR><TD CLASS="quote">FYI, most cars have to drive to 30 mph to get an accurate temp reading. I've read this in previous car manuals Havent read the volvo one, but I wouldnt guess it wouldnt be different...</TD></TR></TABLE><p>I understand that, but this is not a normal condition...maybe I didn't explain it enough...sorry. It reads WELL BELOW ambient, as in yesterday when it was 80-90, it initially read 42. I've seen it read 0 degrees when it was 50 out. It's definitely acting abnormally.
Re: (phuz)
There is a known wiring harness issue. Get to you dealer and have them change the door wiring harness'. I had the same issue with my 06 V50. I work at a Volvo dealership so I am familiar with this issue.<p> <IMG NAME="icon" SRC="http://********************/smile/emcocktl.gif" BORDER="0">
Re: (WA V50 T5)
@ wa v50 t5<br>I have never seen a post from you before, we live super close. what dealer do you work at.
Re: (WA V50 T5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>WA V50 T5</b> »</i></TD></TR><TR><TD CLASS="quote">There is a known wiring harness issue. Get to you dealer and have them change the door wiring harness'. I had the same issue with my 06 V50. I work at a Volvo dealership so I am familiar with this issue.<p> <IMG NAME="icon" SRC="http://********************/smile/emcocktl.gif" BORDER="0"> </TD></TR></TABLE><p>Another Seattle area member! Be sure to come to the GTG that is probably going to happen in July. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: (carreragt7)
No fair. I want to go... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
Re: (WA V50 T5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>WA V50 T5</b> »</i></TD></TR><TR><TD CLASS="quote">There is a known wiring harness issue. Get to you dealer and have them change the door wiring harness'. I had the same issue with my 06 V50. I work at a Volvo dealership so I am familiar with this issue.<p> <IMG NAME="icon" SRC="http://********************/smile/emcocktl.gif" BORDER="0"> </TD></TR></TABLE><p>Done door harnesses countless times. Take the car to the dealer. Depending on the codes stored they can determine whether its due to the faulty door harness connectors.<p>The TNN will require the doors to be removed in the front and have both side connector harnesses cut and new ones spliced in. Every car that i have done has not come back for the previous random door failure complaints <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
my dealer quoted me like 700 for it, i said screw you i'll buy a tune for that much.
Re: (kpsingh0)
Yes, yesterday neither of my rear windows would go up. So I turned off the car for 30minutes then turned it on and they went back up......scared the heck out of me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Sometimes, maybe 10% of the time, when turning the car on, the temperature display will read a much lower value than actual temperature. I think it eventually rebounds to the actual temp., but something is askew. <p> </TD></TR></TABLE><p><br>mine does that too, on hot days sometimes i'll get in the car and the temp will read 113F or something crazy like that. it's no big deal when i drive for a few minutes it readjusts accurately
Discussion Starter · #16 ·
Re: S40 T5 AWD gremlins (max power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>max power</b> »</i></TD></TR><TR><TD CLASS="quote"><p><br>mine does that too, on hot days sometimes i'll get in the car and the temp will read 113F or something crazy like that. it's no big deal when i drive for a few minutes it readjusts accurately</TD></TR></TABLE><p>No, what yours does is completely normal. All cars do that.<br>If you read what this one is doing, it is not normal operation.<p>When yours reads 113F, it is because the UV rays are heating the surface of the sensor or the surrounding area to a higher temperature. When you start moving and pushing ambient air across it, it will drop and read the true ambient temperature.
Discussion Starter · #17 ·
And the gremlins strike again!<p>I guess the gas gauge is reading a full tank when she knows there is no more than 1/2 tank in there. Turn the key off and back on and it will read a different value. Cool, huh!?
Re: (phuz)
My 2007 Completely Cleared of those When I got a New Com Rewrite .<p>An Update to the ECU - also seemed to Smooth Out some Performance<br>Issues . <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0">
Discussion Starter · #19 ·
And thanks to you guys for the heads up....New Door Harness installed today and things are good! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"><p>Have a good weekend.
Re: (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote">And thanks to you guys for the heads up....New Door Harness installed today and things are good! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"><p>Have a good weekend.</TD></TR></TABLE><br>how much is that costing you?
1 - 20 of 22 Posts
