1 - 2 of 2 Posts
Hey
At 114,000 the suspension in my wife's 2.4i FWD is shot. After looking through the suspension threads I will most likely be replacing the struts and associated parts along with the LCA's. Should I look into replacing the springs, links, and stabilizer bar and bushings? These are the only parts on the TASCA diagram that I can't find threads about their replacement. Also, are there any bolts/nuts for these parts that I should replace when I replace the parts.
I will also be replacing the rear struts. Should I look into replacing the springs or other components?
Thanks for the help
Not springs, those are lifetime. Other than that, I would get end links, LCAs, struts and strut mounts. Even the trailing arms can go bad.
1 - 2 of 2 Posts
