Re: S/V70 Mods (scandinaviansled)
Not all the slightly bigger turbo is going to be more laggy than your current one. Bolt on (bigger) intercooler WILL give you lag as well. If lag is what you don't want, then the intercooler upgrade is not for you.<p>There's really no bolt-on IC for GLT, but for T5. I don't think it makes a difference btwn the two models, so you might be able to use the ones that was designed for the T5. Autotech sells one, it's not really a simple direct bolt-on. If you have access to a shop to work on the conversion yourself, then it'll not be too costly. Just the IC cost..<$900, you can get it from Carlos at Texas Automotive Performance.<p>What other upgrades have you done so far? You might get more from other things than IC. Won't really notice much of difference until you have other goodies to go along with it.
