1 - 9 of 9 Posts
Hi,
I have an 06 GT. There is a tube to the left of the oil cap that goes under the blue engine cover
The tube has a slight crack and oil seeps out over time
I'm thinking this is part of the pcv system or something?
Is there a parts diagram I can use to identify and order a replacement?
I may try to epoxy it etc . . . any thoughts . . . .?
Thanks.
replace with part in link
if you need a quick temporary fix i have herd of people having success with heat shrink if you have to wait for a new one to come in. it is part of the PCV breather system.
Holly hell batman . . . my pcv breather tube was cracked in several places
Complete junk @ 70K mils . . . probably since 55K or so
Dealer matched IPD's price
After removing the engine covers (blue) and manifold cover)
I was able to pop the new one in place
A little trouble on the lower part but able to get it secure with the metal clamp in place and some pressure from above
Rock n roll . . . but shame on volvo for a lousy piece . . good thing the new one is an upgraded version
Probably could have had this done under the 8/80K emissions warranty but rather not let the dealer near my R
rock n roll . . . .
Volvo should have put better quality parts on a lot of things. Get use to saying that. Lol.
I believe the newer tubes are of better quality then the originals but I totally agree with you.
The new tubes are actually 2004 R tubes. 05+ had the plastic brittle ones. So when one fails an 04 piece is used to fix it
yep i just did this a week or two ago i had to take out the air box in order to get the bottom clamp on but it can be done. make sure you test the pcv system by putting a rubber glove over the dipstick tube or oil filler hole to verify there is suction after you replace the hose to ensure the system isnt plugged anywhere
the one good thing from the '04 that is still used :D
1 - 9 of 9 Posts
