Hey guys so I recently noticed a certain vibration while idling. I drive a 2008 s60 and it feels like my s60 is struggling to stay on while im idling at a light while in drive. The best way to describe it is the vibration that you feel when you first start your car. I notice this type of rough idle every 5 seconds or so while its in drive. It doesn't make this type of vibration when i have it in park. I started to notice this after one of my pipes on my fmic became disconnected. I was driving and the pipe popped off causing the car to turn off so I got it towed. Every since the pipe was reconnected, this started happening. I also got a CEL that said my oil was too rich. The light went away however and hasnt returned since. As far as my exhaust, i have a 3.5 downpipe with a catless exhaust. I am looking to replace the exhaust with a cat exhaust soon. Does anyone know if theres anything i can do to get rid of this rough idle? I read about replacing the o2 sensors and my s60 has about 105,000 miles on it.
Could be a o2 sensor for sure but when was the last time spark plugs were changed? Could also be the MAF sensor being dirty as well. This is where I would start
Sent from my SAMSUNG-SM-G870A using Tapatalk
Your ecu cannot read and remedy fuel trims without the inputs it needs to calculate.Gas in your oil is a very bad thing.You need the cat and the o2's will signal.Get an analysis on your oil before and after fixing.
Hold up. Your "oil" is too rich? Umm what?
Sent from my HTC One_M8 using Tapatalk
the spark plugs were changed at 65k. last time i checked the MAF sensor wasnt all that dirty. I havent checked the o2 sensors yet. thanks for the feedback and im already looking into getting a catback. i cant stand the constant backfire anymore
