2004 S60r with Stage 2 IPD. HD TCV, Factory lines. Lucky and one of our local Volvo Mechanic/Guru's have already voiced opinion, just seeing if any other ideas were out there before I start taking most of this stuff apart.
The idle is a bit rough.
The car does use a bit of oil, and a tiny bit of coolant. 60k miles and using Amsoil 5-30 or 10-30
Pulled a code with the Softloader of ECM-262A.
I have used a K&N Filter before, and now using the Evolve AMS with the big red filter.
There is no coolant in the oil. There is no oil in my coolant.
The crankcase does show vaccum at idle (rubber glove over oil fill hole, and the glove was getting sucked in).
The one odd thing, my Blitz boost gauge now shows less negative vaccum at idle. It used to read -.07 and below since its as low as the gauge will go.
Now it reads about -.03 at idle.
Plugs have been replaced within 10k miles.
The low oil message has come on once already, and had to add about a 1/2 quart.
I do have an exhaust leak but, I don't think its relevant. The car does not have a Catylic converter, so its a bit hard to tell if the exhaust smells weirder/toxic than normal. (The car hasn't had a cat in over a year, and the rear o2 code for me is normal)
I *MAY* have a vaccum leak at the TCV, I didn't use any of the clamps when I installed the IPD TCV and as far as I recall some of the hoses were a bit hardened. That could be it. I'll replace them with silicone ones anyway.
I was thinking it could be the MAF sensor, or the PCV system? White smoke/leaking turbo?
My plan of attack as I have the AKA Rally comming up in August which is just about 3000 miles form Savannah Georgia, to Monterey Bay California.
At this rate, at 60k miles I'm planning to do some engine maintenance.
-Replace all PCV related components/hoses along with the black box under the intake manifold.
-Remove and clean the Throttle body & Intake manifold, replace gaskets too.
-Clean, then Replace MAF if necessary (otherwise bring it extra)
-Replace and gap plugs a bit smaller.
-Replace exhaust gaskets with graphite ones which form a bit better to uneven surfaces
-Drain, and clean out intercooler of any oil.
-Replace TCV lines with Silicone lines.
Modified by chinaonnitrous1 at 11:35 AM 5-6-2009
