Hi,
My SR is not with me at the moment and I have a question about the front rotors.
If someone has a rotor laying around, could you please measure the width of the ring, the surface contact. I need to know if its about 1 and 1/8th or about 28.575mm.
Thanks in advance!
Keoni.
Hi Keoni,
I measured on of my old front rotors and took some photos for you. I wasn't exactly sure which dimension you wanted measured, so I measured a couple of different dimensions.
The brake pad contact surface is 61.6mm wide:
The hub contact surface is 46.9 mm wide:
I didn't take a photo of the cross-sectional width of the rotor, but the front rotors are 32mm wide when new.
Cheers,
Jeff
Jeff,
I appreciate it a lot!
