1 - 9 of 9 Posts
I have a 20007 XC90 2.3 AWD. I am trying to order rotors and everyone I have talked to says I need to measure them to see what size I need. I eyeballed a tape measure across and read it to be roughly 339mm. Judging by the fact that the only options I see for my set up and age is 316mm or 336mm, am I correct to assume I need the 336mm size?<p>Thanks!!
2021 Volvo S60 T5 AWD
Re: Rotor Question - Need to order ASAP. (mlw911)
Give your Volvo parts dept your VIN and they should be able to tell you from that.
Re: Rotor Question - Need to order ASAP. (njb8199)
Tried that and they were less than specific. Told me to measure as well.
If you measure it to be 339mm, I would think you have the 336mm rotors.<p>It'll be tough to put a tape to the rotors and measure a 316mm rotor as 339, that's a whole 23mm, almost an inch off.<p>Bernard
Re: Rotor Question - Need to order ASAP. (bernardbay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bernardbay</b> »</i></TD></TR><TR><TD CLASS="quote">If you measure it to be 339mm, I would think you have the 336mm rotors.<p>It'll be tough to put a tape to the rotors and measure a 316mm rotor as 339, that's a whole 23mm, almost an inch off.<p>Bernard</TD></TR></TABLE><p> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> Agreed! <p>(Are the larger rotors part of a sport package?)
Re: Rotor Question - Need to order ASAP. (JayTeeC)
I have the larger rotors but no sport package. I thought they were standard on V8 awd.
Re: Rotor Question - Need to order ASAP. (aintsheswede)
That's correct. V8s have the larger rotors.
1 - 9 of 9 Posts
