1 - 14 of 14 Posts
Got everything off without issue with the exception of the rotor screw. That fker is on there and I have nothing to break it loose. Suggestions....
Sent from my Pixel 3a using Tapatalk
You're choice of lubricant (PB Baster is mine)
I used a bit on my impact driver to remove the screw. If you use a wrench, be careful to not put pressure at a weird angle, which is easy to do.
Impact driver, check,... pb blaster check
+1 to the above, impact and PB all day! Just roasted a set of stoptechs because I guess I didnt get my pistons in all the way/ equally pressed in.. Did the job twice. FML.
Get your torx bit on a wrench with a long cheater bar. It's a two person job--one pushes the wrench head with the bit into the screw head so that it stays there while the other is unscrewing.
If an actual impact (1/2 brushless Milwaukee/deWalt or dual hammer pneumatic) and heat doesn’t do it. It’s not a horrible job to drill and recover the threads.
Got it out with a reverse hand impact tool
8yrs of rust in New England is no joke
Yep, same. I’m up into Toronto and use my hand impact driver and a sledge each time on that bi&@$. Helps if you goober it up with anti seize for next time.
Just drill it out, it's not needed
Discussion Starter · #13 ·
As stated previously this is a DONE DEAL, i got it off (READ AND HEED)
I love hammer blow impacts. The satisfaction of hitting something stubborn and it successfully removes that fastener is a mechanigasm.
As a teen I worked on my bike and then that lead to working on tons of others. The damned Phillips head screws on Japanese bike side covers were tightened with some sort of storied martial art bolt tightening process. Hold the pressure on that hammer blow and then smack it GOOD and grunt like a female pro tennis player and damn it those screws jumped out.
1 - 14 of 14 Posts
