<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by datbadboy:<BR><B>want to get 19's to fill up the wheel wells. Any ideas would definitely be helpful. Thanks.</B><HR></BLOCKQUOTE><P>You better stock up on lots of denture glue...You will need it with those 19" (I assume you meant 19-inch as I cannot imagine a C70 with 19-foot wheels!)<P>As far as turning off the DRLs (IMO you should not, they are on for your safety; studies have proved the DRLs' virtues), there is a little screw right next to the headlight switch. RIght now, it is most likely pointing to either 12 o'clock or 1 o'clock. Take a small, tiny screwdriver and turn that screw one or two notches counerclockwise; to 11 o'clock. Your DRLs should be turned off and that switch should function "normally", now.<P>Yannis<P><BR>Yannis<BR><P>
