I just found this setting. I can’t think of any negative to having it on. Knowing the speed limit,etc. is good. However, I need to put it on each time I start the car. Can this setting be saved to each key ?
Yes, just turn it on in the left Sensus panel, save to your driver profile and associated key fob.
You may also want to go to settings so that the Speed limit sign shows up in HUD if applicable. Lastly, some people may adjust RSI in your MyVolvo settings so that it flashes or beeps if you exceed the pre-set threshold.
To each own, the white speed limit box is too much distraction to me. and people constantly drive above speed limit anyways.
So I don't show it on HUD.
