1 - 8 of 8 Posts
Ok so im looking at some 18's and i know they r 5 x108 and used to be on a s60R . What do i need to make them fit since i know we have hub centric ? and where to buy THANKS <p>Josh <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: Rims help (jdsr917)
You would be best getting some hubcentric rings, but the 2mm difference can be made up for if you just hand tighten the lugs after putting the car back on the ground...
Re: Rims help (carreragt7)
Hub rings dont work for me <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: Rims help (Kallvin22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Kallvin22</b> »</i></TD></TR><TR><TD CLASS="quote">Hub rings dont work for me <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> </TD></TR></TABLE><br>why not <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>carreragt7</b> »</i></TD></TR><TR><TD CLASS="quote">You would be best getting some hubcentric rings, but the 2mm difference can be made up for if you just hand tighten the lugs after putting the car back on the ground...</TD></TR></TABLE><p>SO i dont torque the lugz ? i just hand tighten them ? where do i get hib centric rings from ?<BR><BR>
<i>Modified by jdsr917 at 3:21 PM 7-26-2009</i>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jdsr917</b> »</i></TD></TR><TR><TD CLASS="quote"><p>SO i dont torque the screws ? i just hand tighten them ? where do i get hib centric rings from ?</TD></TR></TABLE><p>Torque the lugs first the snug them up a little tighter by hand. It will center the wheel when there is in this case a 2 mm gap between the wheel and the hub. If you get the hub rings you just torque the lugs down and all is good.<br>Hub rings can be found here....<br> <A HREF="http://www.ipdusa.com/Volvo-S40-2005-2010/Wheels-&-Lugnuts/Hub-Centric-Adapter-Rings/p-135-560-5033" TARGET="_blank">http://www.ipdusa.com/Volvo-S4...-5033</A>/
Re: Rims help (mad matt)
40$ for Hub Centric Ring is freaking NUTS <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
Got mine free with wheel purchase from tirerack. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
1 - 8 of 8 Posts
