1 - 14 of 14 Posts
Right now I have a broken/in-the-process-of-breaking collar gear, and I'm not repairing it immediately. Mostly because I want a better part and am waiting for the community effort to put one together, but also because of the risk that the angle gear input shaft will be stripped and/or the collar gear will be fused to the transmission, and the repair will end up costing me thousands of dollars.
The problem with my hesitancy is that driving it around like this increases the chances of the angle gear input shaft being stripped when I finally do repair it.
So right now I'm driving around with the hand brake up two clicks to disable AWD. Logic being that torque will not be applied to the angle gear/collar gear and further destruction of the teeth will be avoided. Is this solid logic or just a dilusion that I am helping anything? Do I risk breaking anything else by riding around like this? Thanks in advance for any info or advice..
Re: Riding with AWD "disabled" (MeisterBrau)
If you're going that route, pull the fuse, not the e-brake...
That being said, no load is better than whatever the car would normally do - however those parts are always moving, even with the driveshaft removed, so you do still risk irreparable damage driving it around http://********************/smile/emthdown.gif
Adam is right.
Torque will still be on the collar, just not on the angle gear. With the failed collar, I believe you will be driving around with front-left wheel traction only
It's broken or it's not broken, it can't be a little bit pregnant, it either is or it isn't!
BAD idea to leave it alone as you will be waiting a very long time (forever) for an "upgraded" gear.
Re: (phuz)
Quote, originally posted by phuz »
Adam is right.
+1
that "myth" was "dispelled" here
I am not sure who to believe
Re: (FEO)
Quote, originally posted by FEO »
That makes perfect sense. I was never aware of that.
Re: (phuz)
You will never have one-wheel drive, unless a half shaft breaks, but even then you'll effectively by zero-wheel drive since the R has open diffs and I don't think TRACS is up to that task haha.
Alex, I sent my old SM an email asking him to inquire the tech about the fitment of the new collar on the shaft. He said they come preassembled with the new transmissions, but the protocol requires them to heat up the new collar in an oven (for expansion purposes) and then place it on the spline shaft and allow it to cool. After its on, it requires a puller to remove. He said there is VERY little play which leads me to believe the teeth are meshing quite nicely, which contradicts what you showed me on the VS page where the teeth are only in about 50% mesh.
Thoughts?
Re: (phuz)
Thoughts?
What spline shaft are you talking about? On the transmission? If so, I think that the main concern was the bad fitment on the angle gear side of the collar.
What does "VERY little play" mean? trying to induce play by torquing it with your hand is a lot less than 400-500 ft-lbs of torque when in operation. Morevover, the fact that there would be any discernible play would be VERY concerning, as we're not talking about instantaneous failure but a positive feedback of increased wear leading to increased play leading to increased wear...etc.
Cheers,
J
Re: (soupandspoons)
Quote, originally posted by soupandspoons »
Cheers,
J
"very little play" means that its a tight fit and the mesh isn't sloppy at all. From previous posts, I gathered that the meshing of the spline/collar wasn't too pretty.
Re: (phuz)
When I replaced mine with the new nitride coated one, it was cold in the garage and it slid right on and was sloppy as hell. I think someone is FOS about having to heat it up.
Re: (llabahn)
Quote, originally posted by llabahn »
Interesting. I wouldn't think a tight fit, perfect meshed unit would have failure issues, but if they are anything like what you are describing, then yes...big time.
Re: (llabahn)
but when you replaced yours, it had stripped already so major wear would be showing
just my .02
Re: (FEO)
Yes, there was moderate wear only on the angle gear side. That's the side that was loose. But it slid on the transmission shaft easily too.
I'd love to see a how tightly a brand new angle gear and sleeve fit together.
1 - 14 of 14 Posts
