Pulled the car onto ramps in order to service stage 0. Car has had the chassis settings service light since i bought it. One the ramps the chassis service warning is off. But car on level ground its back on. Looked real close at struts and found no leaks. Seems like a loose connection to me.
What say ye?
yeah it sounds like a connection, check your mounts and etc.
and as JCN said if its a sensor which it probably is you need vida.
Dude the 'chassis settings service' is an idiot light. From there you need to scan the car with volvo software and such. There are many posts on this right here on SS and on the other 4-5 volvo forums... Loose connection? whatever. You can't find it w/o vida since it'll tell you which one of the four sensors or whatever is causing, e.g. the SUM module may be cooked if that old car's heater core leaked (yeah the sum module is right below heater core). Just use google to search ...not the SS forum
