I am on a quest to retrofit the oem rear seat heaters on a 2012 S60 T5 before winter. Since this was a functionality was available on 2013+ models, I figured I would give it a try. All the wiring for the switch, seat heater modules and the heater pads etc was already installed at the factory. I have installed the rear seat heater pads between the foam and the leather/vinyl, the rear center control switch, both separate rear seat heat modules and using VDASH activated the functionality in the CCM. The switch is now activated, it has power, but I have no heat. Aside from fuses that may be missing since this is a retrofit, anything else I'm missing that would prevent these things from getting hot? I bought a used rear center control switch in the hope of not having to go to the dealer to get software programed.
Any thoughts? :confused:
Did you try just hardwiring to the battery and a ground to see if they do heat up? Eliminate the heaters themselves.
