anyone do a write up or is this a simple straightforward swap-in?
Isn't it much like the spark plug install write-up, minus the spark plugs? Just unclip each coil pack and reconnect, right?
Exactly, take your time & be as gentle as you can with the connectors. Maybe even blow off with compressed air & use some silicone spray to help the clip release easily. Everything plastic gets so brittle from the engine heat it's very easy to break.
good look. thanks guys.
This. I took a vacuum to the area underneath the engine cover as it was pretty dusty. You don't want that going into your engine.
