I replaced my 100K mile rear shocks (dampers) with Bilstein B6 no trouble - so easy. The fronts are another story but I knew that going in.
I followed the YouTube video here (minus pulling the hub from the axle) and ended up tearing the lower control arm boot (womp womp). I got the shock out and dis/reassembled fine - and the new control arm in - but I cannot get the steering knuckle hole and control arm ball joint stud to line up, partly/mostly because I cannot force the control arm down enough. This would be a problem regardless of the new control arm or not. I noticed in the video he edited out his control arm struggle.
Any help, guidance, thoughts, or prayers on how to push the control arm lower to get the knuckle into place?
Thanks
Thanks
