Re: Replacing air filter, 2.4i engine (eagle2x)
Just be really careful of three things:
1) be sure the airbox interior is clean before reinstalling the filter. Grit often falls to the bottom on the clean side when removing, and it can go straight into the engine from there.
2) be careful to get the rubber seal (#5 above) lined up correctly so it follows the ridges and isn't pinched or out of place. It's tricky, check twice.
3) don't use the screws to push the filter module "home". Line it up and push it by hand, then simply snug the screws.
Tom.
