1 - 2 of 2 Posts
I replaced my battery yesterday because there was corrosion on the negative terminal due to a small crack. The corrosion spread up the cable, so I need to replace it. Trouble is, I can't seem to find the exact part I need, or directions. Can anyone recommend a part store?
I've used Tascaparts.com before. I found the negative battery cable but they don't list a part number with it for some reason. If you look under Electrical - chassis electrical - battery - negative cable you'll find it. This link may also work
1 - 2 of 2 Posts
