Hi, I just replaced a side view mirror glass on my XC90, now the motor makes a clicking sound every 2 seconds while adjusting the mirror. Did I brake something? :confused:
its not seated properly, look up install instructions here or on ipd
those are correct, I suspect nothing is broken, you just need to remove it, make sure it "hooks" properly when you reinstall, click the outer side in well, run it to it goes thru all the motions, there will be some clicking sounds, and then should work fine
you can also run the motor when the mirror is out to see if it still makes a noise, I suspect not
