1 - 8 of 8 Posts
Re: replace my drl's with white bulbs (SDS40)
No you do not need to disconnect the battery when you replace bulbs. Also are your refering to the center city lights or your actual DRL's which are your low beam bulbs?
Yep, any H11 bulbs should work with a simple swap. I replaced my bulbs several times without disconnecting the battery, so as long as the car is off, I don't see a reason why the battery needs to be disconnected.
aren't the low beams H7 bulbs? (at least thats what I bought for replacing them...) <br>correct me if I'm wrong.
Re: (crossie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>crossie</b> »</i></TD></TR><TR><TD CLASS="quote">aren't the low beams H7 bulbs? (at least thats what I bought for replacing them...) <br>correct me if I'm wrong.</TD></TR></TABLE><p>Low beams and fog lights are H11. High beams are HB3 I think
Re: (lando_pr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>lando_pr</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Low beams and fog lights are H11. High beams are HB3 I think</TD></TR></TABLE><br>crossie, you are correct. However, you live in Germany, as I once did and have the better equipment. I learned while I was there that yours ...and now mine (since I have euro spec lighting) have H7 bulbs. The A-Spec S40/V50 use the H11 bulb. I am so glad I switched <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: (lando_pr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>lando_pr</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Low beams and fog lights are H11. High beams are HB3 I think</TD></TR></TABLE><p>high beams are 9005
1 - 8 of 8 Posts
