1 - 10 of 10 Posts
I purchased replacement high beams for my XC60 (2014). The car came with xenon headlights - and I want to replace the remaining halogen bulbs with something whiter. I can get the housing out of the car; I can remove the door that provides access to the bulbs; I can remove the connector; but I can't get the bulb out.
The instructions (owners manual) say to just pull it out - but it won't pull. It will rotate (approx 30 degrees) - but does not pull out then either.
Ideas are welcomed.
I will have to replace the D3S HID bulbs also, and I don't have experience how to do it
Does anybody know? Is it complicated? Any post referring to replacement of Volvo hid low beam bulb with active bending light? Thanks
Instructions in manual will get you to the bulbs. The removal of the bulbs is the issue. I'm sure that it is not hard - once you know how.
1 - 10 of 10 Posts
