Which parts are typically replaced when changing the aux belt?
idler roller
belt tensioner
coupling
pullley
ac clutch
Please advise if these items are correct or not and if other items should be added.
I have a guide for this if that helps.
https://www.volvoforums.org.uk/showthread.php?t=269018
When I asked the dealer about the job they told me to consider replacing the Ac clutch/pulley at same time. Apparently they have seen a few of these go and take the compressor out with it.
Don't forget to check the clutch on the alternator pulley, it should slip smoothly in one direction. Mine was seized and would break the drive belt regularly.
