1 - 19 of 19 Posts
Banned
A few weeks ago I took out the instrument cluster in a '92 244, and when I put it back in the trip odometer and odometer ceased to function. I pulled it out again, took it apart, and true to form all the gears were in perfect condition-teeth and all. It took about 60 miles of driving for the odometer/trip odometer to begin working, and they continued to work even after I reset the trip odometer some three times after going some 200 plus miles.
Last Saturday I took out the cluster(without disconnecting any wires) to take a picture of the back, and when I had put it back in, the odometer and trip odometer had once again decided not to work. How I should tackle this I do not know. Any help would be greatly appreciated....Thanks
p.s. Sorry for the same topic being contionously rehashed
Banned
Re: Reoccuring issue with the odometer and trip odometer...... (1sciroccofahrer)
The odometer and trip odometer still haven't begun working again
I can still move the numbers manually, but after having replaced the antenna mast yesterday evening, this is one of the last issues troubling the '92 240. Thanks in advance
Banned
Re: Reoccuring issue with the odometer and trip odometer...... (gdill2)
I am afraid so
Once I get the odometer and trip odometer working again, I am never going to pull the cluster-even though, after all this time, I am quite proficient at it
Modified by 1sciroccofahrer at 1:15 PM 4-27-2006
Banned
Re: (DVolvoguy777)
Thanks VolvoGuy...Those photos will be quite helpful indeed! When I return home this afternoon, I am going to take the cluster out, bring it into my computer room, and have another look at it. Have a splendid afternoon one and all
Banned
Re: (1sciroccofahrer)
I just pulled the cluster, and took a look at all the gears, and they are in great shape with all of their teeth intact. I am going to take the car out later to go to the grocery, and I can only hope that the odometer/trip odometer begin to work once again. Have a most wonderful evening http://********************/smile/emthup.gif
you may have to take it into a speedometer shop to get it diagnosed. im sure theres one in your area. i know this probably isnt the answer you were looking for but it seems to be out of the reach of anyone but a specialist.
this is a bit off topic but Sprechen sie Deutsch?
Banned
Re: (Camyman)
There is indeed a Speedometer repair facility a little less than eight miles from where I am, but I am not yet at the point where I am going to admit defeat. A week from now I might just be singing another tune
Eigentlich kann ich leider kein Deutsch sprechen, aber Bayerisch(Frankisch) kann ich
Banned
Discussion Starter · #16 ·
Because I was done with all my chores for the day, I pulled the instrument cluster and took another look at all the gears. Both the small white gear, and the larger black gear were in perfect condition, so I put the cluster back together and took the car for a spin. True to form, it would not work. I am going to pull the cluster again, and see if I can't try out a few variables, and who knows, I might just get lucky
Hope everyone here is enjoying their Saturday
when you have it out see if the gears turn the numbers. if not then id run outside as soon as possible in a bathrobe with a bedpan and a wooden spoon and walk down the middle of the street banging on the bedpan with the wooden spoon screaming "the swedish are coming, the swedish are coming!" then try a dabble of white lithium grease on the gears and try again.
Banned
Discussion Starter · #18 ·
Re: (Camyman)
I am able to manually move the odometer/trip odometer when I have taken the side out of the speedometer cluster and the little(and big) gear are out. I will try the white lithium grease trick tomorrow and see how it works out
Have a great Saturday evening Camyman
Banned
Discussion Starter · #19 ·
I took the speedo cluster out, with the little and big gears still in, and was able to manually move the numbers. I applied a little lithium grease (with a q-tip) to both the small and big gear(s), and after I reassembled everything the odometer/trip odometer still wouldn't work. I have a theory that perhaps when I take out the small and big gear(s) that perhaps when I put them back the small gear isn't making contact to the to clear plastic piece. Now that I have mowed the lawns and cleaned the bathrooms, I can devote the afternoon to this ongoing conundrum
1 - 19 of 19 Posts
