1 - 10 of 10 Posts
Using Mozilla, the "Marketplace" tab is not in line with the other tabs under the top banner. This occurs in Mozilla both for Linux and Windows
Re: Rendering error with Mozilla (devalmyth)
<BLOCKQUOTE>quote:<HR>on my screen, the bottom quater of those tabs(all of them )are cut off.<HR></BLOCKQUOTE><p>Mine too. I'd say the bottom 1/4 of the entire top frame, which equates to almost the entire word being hidden ("home, news, features, forums", etc.). I usually just open the frame in a new window and go from there. Win98, Netscape v4.77.
<BLOCKQUOTE>quote:<HR>on my screen, the bottom quater of those tabs(all of them )are cut off.am running XP<p>michael.<HR></BLOCKQUOTE><p>What browser are you using?<br>XP Home? or XP Prof?
Seems good on the computers I post (ho) with. Windows '98, NT 4.0 & XP. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> Could be an individual configuration thing maybe?
Re: Rendering error with Mozilla (Spearzy)
I think I know what the half-tabs are. The frameset looks like it must use some kind of proportional setting (i.e. something like frameset 30%,70%) instead of a fixed size of pixels. So when you resize your window, (or use the browser on a computer with a different screen resolution) you can make the tabs cut off.
Re: Rendering error with Mozilla (joeflies)
<BLOCKQUOTE>quote:<HR>I think I know what the half-tabs are. The frameset looks like it must use some kind of proportional setting (i.e. something like frameset 30%,70%) instead of a fixed size of pixels. So when you resize your window, (or use the browser on a computer with a different screen resolution) you can make the tabs cut off.<HR></BLOCKQUOTE><p>Good point joe, I almost forgot that not everyone runs their desktop at 1280x1024.<p>devalmyth, what res do you run?
Re: Rendering error with Mozilla (Kaizai)
<BLOCKQUOTE>quote:<HR>I think I know what the half-tabs are. The frameset looks like it must use some kind of proportional setting (i.e. something like frameset 30%,70%) instead of a fixed size of pixels. So when you resize your window, (or use the browser on a computer with a different screen resolution) you can make the tabs cut off.<HR></BLOCKQUOTE><p>This is exactly the problem. I'm using 800x600.<p>George, if you can change the HTML code for the main page, it should be an easy fix. From the main page, "view source" and see the 8th line of code, "<frameset rows="75,508"...". I think that's the problem. The top frame should have a row height of 75 pixels, and the lower frame should have a row height of 508 pixels. For some reason the lower one is overlapping the top frame, so change the "508" to "*" and it should display correctly. That way the lower frame will start where the first frame ends, and extend down as far as needed. It worked for me when I tested it, but I was using win2k and an older 4.xx netscape browser, so check it out on other systems first.
1 - 10 of 10 Posts
